12 Replies Latest reply on Jul 14, 2014 3:52 PM by Stephen King
    sheet metal die Ghosting the strip layout in a drawing
    Stephen King
      Shown here is a view of a sheet metal die design in an assemby.
      Shown here is a Lower plan view of the assembly drawing, showing the Ghost strip. The strip is clear (Wire Frame) and creates no hidden lines behind it.
      I would like to use the strip that is already in the assembly (like what shown above) so that way the strip would be in place. I am not able to get the results I
      need by using a config or display state, I'm not saying it can't be done, just I hav'nt found a way, and maybe solidworks can't do it, I'm not sure.
      See last picture.
      The only way I found that works "kinda", is while your in drawing, bring the strip in thru model view.
      The big problem there is Aligning the strip exactly.
      Thank you
