Hello All,
I am trying to edit and add to the list of Manufacturers for SW electrical symbols and parts. So far, the only way I have found to add manufacturers is by manually typing a new name in the Manufacturer field of an added part in the Manufacturer Parts Manager (pictured attached). I will create a blank part just to add the manufacturer. Then, that name will appear as an option in the symbol library and other places.
Now I am running into trouble because I can't remove a manufacturer once entered. I mistakenly started with KONNISBERG when it should have been Konnisberg. Even after all the parts with KONNISBERG have been deleted the name still remains.
I am hoping that there is some field, list, or option, where I can make all of these edits at once.
Thanks for any assistance you can provide.
Jordan Woods-Wahl
SW Electrical 2014
You are correct, you have to add a part for a manufacturer to show up. I suggest in the future using the dropdown box when you want to use that manufacturer, instead of typing it again.
If you need to delete a manufacturer, delete all of the parts under that name. Then restart the program and it will be gone.
