2 Replies Latest reply on Jul 11, 2014 9:04 AM by Sushil Chaskar
    Parting line Algorithm
    Sushil Chaskar
      Hi.. Actually I am starting to work on code that will get best possible parting line and show on the model.. Can you guys please suggest as to how should I proceed with the algo..?
        • Re: Parting line Algorithm
          Ar K
          Hi :-)
          Are You work in Mold Design Field ?
          What is your problem ?
          http://www.deepdyve.com/lp/elsevier/automatic-determination-of-parting-directions-parting-lines-and-XD24MF8IOj
          VB.net example :
                  Dim swDoc As ModelDoc2 = Nothing
                  Dim swPart As PartDoc = Nothing
                  Dim swDrawing As DrawingDoc = Nothing
                  Dim swAssembly As AssemblyDoc = Nothing
                  Dim boolstatus As Boolean = False
                  Dim longstatus As Integer = 0
                  Dim longwarnings As Integer = 0
                  swDoc = swApp.ActiveDoc
                  swDoc.ClearSelection()
                  boolstatus = swDoc.Extension.SelectByID2("Parting Line1", "BODYFEATURE", 0, 0, 0, False, 0, Nothing, 0)
                  Dim swSelectionMgr As SelectionMgr = swDoc.SelectionManager
                  Dim PLFeat As Feature = swSelectionMgr.GetSelectedObject6(1, -1)
                  Dim swPartingLine As PartingLineFeatureData = PLFeat.GetDefinition
                  Dim i As Int16 = swPartingLine.GetPartingLinesCount
                  Dim edgVar() As Object
                  edgVar = swPartingLine.PartingLines
                  Dim edg(edgVar.Length - 1) As Edge
                  For j As Integer = 0 To edg.Length - 1
                      edg(j) = edgVar(j)
                  Next
                  Dim x As Double = edg(0).IGetStartVertex.GetPoint(0)
