Is there a way to make a feature similar to a belt/chain where one of the entities is linear? I want to model a pully moving a lever.
Yes, that's almost exactly it, except for two minor differences:
I'm more interested in mating the two components than modeling the link itself.
For simply mating the motions of the levers and pulleys you might be able to use gear mates. It might not be perfect but maybe it is close enough for your purposes.
If you are looking for a way to model the belt so that it updates dynamically as you move a lever, that will be very difficult. I think maybe the best you can do is draw it in context of the assembly with the ends tied to the levers. Then after you move the levers a rebuild would update the belt.
