Good morning all,
I have a need to perform a search using vba within excel. I have the code working, kind of, but I search on the variable "ECN" and only get 12 of 34 results to populate.
I am trying to populate a list of drawings affected by an ECN by searching the database and then returning various variables into a excel spreadsheet that is used for distribution of the ECN.
Here is my code as of thus far. Hopefully someone can spot a silly misttake.
Sub FindFiles()
Dim eVault As IEdmVault5
Dim eSearch As IEdmSearch5
Dim eResult As IEdmSearchResult5
Dim eFile As IEdmFile5
Dim eFolder As IEdmFolder5
Dim EnumVar As IEdmEnumeratorVariable5
Dim Var As Variant
Dim strVar As String
Dim ConfigList As EdmStrLst5
Dim Configuration As String
Dim pos As IEdmPos5
Dim RowIndex As Long
Dim test As Long
Dim FileCount As Long
Dim vaultName As String
Dim adminPassword As String
RowIndex = 7
FileCount = 0
vaultName = "Insert name here"
adminPassword = "Insert Admin Password Here"
Set eVault = New EdmVault5
eVault.Login "admin", adminPassword, vaultName
Set eSearch = eVault.CreateSearch
Var = Range(Cells(3, 23), Cells(3, 23))
eSearch.AddVariable "ECN", "3842"
Set eResult = eSearch.GetFirstResult
While Not eResult Is Nothing
FileCount = FileCount + 1
'Debug.Print eResult.Name
If LCase(Right(eResult.Name, Len(eResult.Name) - InStr(1, eResult.Name, "."))) = "slddrw" _
Or LCase(Right(eResult.Name, Len(eResult.Name) - InStr(1, eResult.Name, "."))) = "dwg" _
Or LCase(Right(eResult.Name, Len(eResult.Name) - InStr(1, eResult.Name, "."))) = "xls" _
Or LCase(Right(eResult.Name, Len(eResult.Name) - InStr(1, eResult.Name, "."))) = "xlsx" _
Or LCase(Right(eResult.Name, Len(eResult.Name) - InStr(1, eResult.Name, "."))) = "doc" _
Or LCase(Right(eResult.Name, Len(eResult.Name) - InStr(1, eResult.Name, "."))) = "docx" _
Or LCase(Right(eResult.Name, Len(eResult.Name) - InStr(1, eResult.Name, "."))) = "idw" _
Then
Set eFile = eVault.GetFileFromPath(eResult.Path, eFolder)
Set ConfigList = eFile.GetConfigurations
Set pos = ConfigList.GetHeadPosition
Configuration = ConfigList.GetNext(pos)
Set EnumVar = eFile.GetEnumeratorVariable
EnumVar.GetVar "ECN_Purchasing To Review", Configuration, Var
strVar = CStr(Var)
'Debug.Print " PTR: " + strVar
Range(Cells(RowIndex, 2), Cells(RowIndex, 2)) = strVar
EnumVar.GetVar "ECN_Document Status", Configuration, Var
strVar = CStr(Var)
'Debug.Print " Status: " + strVar
Range(Cells(RowIndex, 3), Cells(RowIndex, 3)) = strVar
EnumVar.GetVar "Book", Configuration, Var
strVar = CStr(Var)
'Debug.Print " Book: " + strVar
Range(Cells(RowIndex, 4), Cells(RowIndex, 4)) = strVar
EnumVar.GetVar "Book Section", Configuration, Var
strVar = CStr(Var)
'Debug.Print " Section: " + strVar
Range(Cells(RowIndex, 5), Cells(RowIndex, 5)) = strVar
strVar = Left(eResult.Name, InStr(1, eResult.Name, ".") - 1)
'Debug.Print " DWG/DOC: " + strVar
Range(Cells(RowIndex, 6), Cells(RowIndex, 6)) = strVar
EnumVar.GetVar "Revision", Configuration, Var
strVar = CStr(Var)
'Debug.Print " Rev: " + strVar
Range(Cells(RowIndex, 9), Cells(RowIndex, 9)) = strVar
EnumVar.GetVar "REV Description", Configuration, Var
strVar = CStr(Var)
'Debug.Print " Desc. of Change: " + strVar
Range(Cells(RowIndex, 10), Cells(RowIndex, 10)) = strVar
RowIndex = RowIndex + 1
Set eResult = eSearch.GetNextResult
Wend
Debug.Print FileCount
