When I check the properties of the cutlist of my part, some evaluated values are missing. Does anyone know why these values are not updated?
Hello Simon,
It seems that the issue is with in context reference. When you break it, these values will be calculated.
Additionally, when you want to insert body to new part, try to use "Insert part" command or "Mirror part" if it is mirror. In these two cases you can transfer cut list properties so you won't be forced to break external references.
Kind regards.
I ran into the same issue today on some mirrored sheet metal parts. Have you found a solution?
