1 Reply Latest reply on Jul 9, 2014 4:24 AM by Sean Phillips
    How to get dimensions that are not "Display Dimensions" From Model
    Adam Hoffman
      I'm trying to write a macro that processes dimensions in our assembly drawings but am having trouble. All the examples I have seen say to get the first display dimension in the view and then use GetDimension on the display dimension. Correct me if I am wrong, but display dimensions are used in the model right? What about dimensions that were added to the drawing manually after the drawing was created? I can't seem to gain access to these. I've tried going the GetAnnotation route with the overall drawing itself and then call GetType on the annotation returned but dimension does not seem to be in that category. Any help would be appreciated, Thanks.
        • Re: How to get dimensions that are not "Display Dimensions" From Model
          Sean Phillips
          Get Annotation first, then displaydimension, then dimension, then dimenisontolerance.
          Annotation is everything in a drawing part assembly. from annotation you can check the type, and hand over to the appropriate object. for example displaydimension. from displaydimension you can get dimenion. this dimension has properties such as readonly and driven, override ect. from dimensions we can get dimenisontolerance.
          Private _Annotation As Annotation
                        Private _Note As Notes
                        Private _DisplayDimension As DisplayDim
                                  Private _Dimension As Dimension
                                           Private _DimensionTolerance As DimensionTolerance
                        Private _Block As Blocks
                        Private _CenterLine As CenterLines
                        Private _CenterMarkSym As CenterMarkSyms
                        Private _CThread As CThreads
                        Private _CustomSymbol As CustomSymbols
                        Private _DatumOrigin As DatumOrigins
                        Private _DatumTag As DatumTags
                        Private _DatumTargetSym As DatumTargetSyms
                        Private _DowelSym As DowelSyms
                        Private _Leader As Leaders
                        Private _Gtol As GTols
                        Private _RevisionCloud As RevisionClouds
                        Private _SFSymbol As SFSymbols
                        Private _TableAnnotation As TableAnnotations
                        Private _WeldBeadSymbol As WeldBeadSymbols
                        Private _WeldSymbol As WeldSymbols
          ModelItems is the key to change dimensions on a drawing. if the dimesion was created on the drawing. your only option is the override the value. thats ugly. make sure to check a modelitem for readonly, and driven state.
