I was wondering what exactly should be the gap between slider parts so that they will slide smoothly but stays in place.
You'll have to look at the tolerance from the 3D printing process. Then leave enough gap so that if the slot is undersize by the max amount and the sliding part is oversize by the max amount they will not interfere.
John,
Like Per Enberg said - it depends on the type of 3D printer you are using. is it SLA, SLS, ObJet or FDM?
Also, what type of fit do you need - what is the application? Provide a screen shot so that I don't have to d/l and open your parts. I will give you my opinion on a clearance if you answer these questions. Roland mentioned a food grade silicone. I have not used that material for lubrication, but I have used butcher's wax which also works well. Will that parts be finished (sanded smooth) before assembling? Sanding will remove material and the parts can be fit to you liking even if the parts are modeled line-to-line.
-Nate
I would start a little bit tight at like .002" to .003" clearance. As you slide these back and forth a few times FDM printed parts will "loosen up" a little bit. If you are wanting these in ABS you could acetone smooth the surfaces as well, which would help. If you need help let me know.
Corey Hinman
www.entre3d.com
John,
-Nate
