How to define the polynomial on spline constructed from points imported using scanto3D
Question asked by Karthik Pingle on Jul 7, 2014
Hi all,
I have a point file which contains the points for a spline (of a spur gear). I have imported the points using the 3D to scan add on in solidworks.
Next, using the curve prep wizard, i have joined the points. Here i am facing 2 problems.
1. The curve fit option basically joins the points . Is it possible to get the polynomial used by solidworks to fit the points?? This is intresting for me as i need to decide which polynomial order fits the points best and also to decide the optimal no. of points that i need to use.
2. Is it possible to calculate the deviation of the spline (created by the curve fit wizard) from the actual points??
Awaiting for your suggestions. Thanks
Karthik
