4 Replies Latest reply on Jul 7, 2014 6:52 PM by Sushil Chaskar
    Getting offset planes..
    Sushil Chaskar
      Trying to get no. of planes automatically.. Getting error as Object variable not set in bolded line.. Any help ?
      Dim swApp As Object
      Dim Part, Model As Object
      Dim planeName, newPlaneName As String
      Dim planeFeature As Object
      Dim i, planeCount As Integer
      Set Model = swApp.ActiveDoc
      If Model Is Nothing Then
      Exit Sub
      newPlaneName = "Plane1"
      planeCount = 0
      For i = 1 To 5
      Model.ClearSelection
      Model.SelectByID newPlaneName, "PLANE", 0, 0, 0
      Model.CreatePlaneAtOffset 0.1, 0
      planeCount = planeCount + 1
      planeName = "Plane" & planeCount
      newPlaneName = "MyPlane" & i
      Set planeFeature = Model.FeatureByName(planeName)
      planeFeature.Name = (newPlaneName)
      Model.EditRebuild
      Next
        • Re: Getting offset planes..
          Artem Taturevych
          You do not have a features with names Plane1, Plane2, Plane3, Plane4, Plane5
              Sushil Chaskar
              Artem, thank you. Can you suggest changes in algo.
                  Artem Taturevych
                  Hi, Try this:
                  For i = 1 To 5
                  Set planeFeature = Model.CreatePlaneAtOffset3 (0.1, False, True)
                  planeFeature.Name = newPlaneName
                  Model.EditRebuild
                  Next
                  Also make sure that you have a master plane named 'Plane1' or change this line to appropriate name:
                      Sushil Chaskar
                      Thank you very much.. Can you do me another favour ? Been trying to get 3d intersection curves between plane and model for number of planes.. Did this way..For this, first I am selecting all faces of model, then getting plane count and then creating 3d intersections for each plane. But getting only one skech... Can you suggest ?  FI: count1 is number of faces and Count is number of planes (including basic three planes)
                      Option Explicit
                          Dim swSelData As SldWorks.SelectData
                          Dim swPart              As SldWorks.PartDoc
                          Dim swBody              As SldWorks.Body2
                          Dim swFace              As SldWorks.Face
                          Dim swEnt               As SldWorks.Entity
                          Dim bRet                As Boolean
                          Dim vBodies             As Variant
                          Dim boolstatus         As Boolean
                           Dim count1 As integer
                           count1 = 0
                          Set swModel = swApp.ActiveDoc
                          Set swPart = swModel
                          Set swSelData = swSelMgr.CreateSelectData
                          vBodies = swPart.GetBodies2(swAllBodies, True)
                          Set swBody = vBodies(0)
                          Set swFace = swBody.GetFirstFace
                          swModel.ClearSelection2 True
                          Do While Not swFace Is Nothing
                              Set swEnt = swFace
                              ' Select through Entity
                              bRet = swEnt.Select4(True, swSelData): Debug.Assert bRet
                              Set swFace = swFace.GetNextFace
                               count1 = count1 + 1
                      Loop
                          Dim Count As Integer
                          Count = 0
                          Dim swfeature As SldWorks.Feature
                          Set swfeature = swModel.FirstFeature
                         While Not swfeature Is Nothing
                         If swfeature.GetTypeName = "RefPlane" Then
                         swfeature.Select2 True, 0
                            Count = Count + 1
                           Set swfeature = swfeature.GetNextFeature
                        Wend
                        MsgBox Count
                          Dim i , j As Integer
                          For i = 1 To Count - 3
                          boolstatus = swModel.Extension.SelectByID2("Plane" & i, "PLANE", 0, 0, 0, False, 0, Nothing, 0)
                          swModel.SketchManager.InsertSketch True
                          swModel.Sketch3DIntersections
                          For j = 1 to count1
                      boolstatus = swModel.Extension.SelectByID2("Face" & i, "FACE", 0, 0, 0, False, 0, Nothing, 0)
                          Next j
                      Next i
