I am trying to make a thread with a run-out. I have been able to do this using a swept base (adding the thread to the base part) but have been unable to do so with a swept cut. The attached file is the simplest way to show the problem. If you edit the helix feature and increase the diameter of the third region, the feature fails to regenerate properly.
Please suggest how to fix this problem.
you got there helix with variable pitch and there are defined diameters for each pitch separately. These diameters must have the same value. The best would be to do a link with the diameter of the cylinder
