1 Reply Latest reply on Jul 4, 2014 4:59 PM by Sushil Chaskar
    Getting 3d intersection curves..
    Sushil Chaskar
      Hi.. I don't know how to get 3d the intersection curves between modeldoc and number of planes automatically. I think first we need to select all faces of model, then use firstfeature to automatically select each plane and get 3d intersection curve on model. I did it manually i.e. hardcoded way but I need a general method that will work for every case. Any help guys. I also want to know how we can get the extreme points of model doc or possible max and min values of x, y, z coordinates.. Plz help me out guys...
        • Re: Getting 3d intersection curves..
          Sushil Chaskar
          There need some changes to be made... Any thoughts..?
          Option Explicit
          Dim swSelData As SldWorks.SelectData
          Dim swBody As SldWorks.Body2
          Dim swFace As SldWorks.Face
          Dim swEnt As SldWorks.Entity
          Dim bRet As Boolean
          Dim vBodies As Variant
          Dim boolstatus As Boolean
          Dim count1 As Integer
          count1 = 0
          Set swModel = swApp.ActiveDoc
          Set swPart = swModel
          Set swSelData = swSelMgr.CreateSelectData
          vBodies = swPart.GetBodies2(swAllBodies, True)
          Set swBody = vBodies(0)
          Set swFace = swBody.GetFirstFace
          swModel.ClearSelection2 True
          Do While Not swFace Is Nothing
          Set swEnt = swFace
          ' Select through Entity
          bRet = swEnt.Select4(True, swSelData): Debug.Assert bRet
          Set swFace = swFace.GetNextFace
          count1 = count1 + 1
          Loop
          MsgBox count1
          Dim Count As Integer
          Count = 0
          Dim swfeature As SldWorks.Feature
          Set swfeature = swModel.FirstFeature
          While Not swfeature Is Nothing
          If swfeature.GetTypeName = "RefPlane" Then
          swfeature.Select2 True, 0
          Count = Count + 1
          Set swfeature = swfeature.GetNextFeature
          Wend
          MsgBox Count
          Dim i, j As Integer
          For i = 1 To Count - 3
          swModel.SketchManager.InsertSketch True
          swModel.Sketch3DIntersections
          boolstatus = swModel.Extension.SelectByID2("Plane" & i, "PLANE", 0, 0, 0, False, 0, Nothing, 0)
          For j = 1 To count1
          boolstatus = swModel.Extension.SelectByID2("Face" & j, "FACE", 0, 0, 0, False, 0, Nothing, 0)
          Next j
          Next i
