3 Replies Latest reply on Jul 5, 2014 1:36 AM by Deepak Gupta
    Extracting filename to custom properties
    Jeremy Harris
      I've spent a few hours on this forum trying to learn how to create a Macro to extract from the file name and import the info into the relevant custom properties. I have no knowledge with macros but have tried to pick up some things as I go along so I apologise if this is really basic.
      I've succeded in extracting the necessary info into the DWG No. and Description fields.
      Only issue I currently have is that for the description, it keeps including the ".SLDPRT" or ".SLDASM"
      I've tried a few methods to instruct it to replace it with nothing but I keep getting errors?
      On the Macro so far, the description section is:
          If swModel.CustomInfo("DWG No.") = "" Then
            swModel.AddCustomInfo2 "DWG No.", swCustomInfoText, Left(swModel.GetTitle, 11)
          Else
              swModel.CustomInfo("DWG No.") = Left(swModel.GetTitle, 11)
      What would I have to do to remove the extension from the new custom properties description?
        • Re: Extracting filename to custom properties
          Sean Phillips
          this is crude because I would use system.io.fileinfo.
          str = Mid(myfilename, 1, Len(myfilename) - 7)
              Sean Phillips
              Add Reference “Microsoft Scripting Runtime”
              ' C:\Users\SEAN\AppData\Local\Temp\swx5900\Macro1.swb - macro recorded on 06/22/14 by SEAN
              Dim swApp As Object
              Dim Part As ModelDoc2
              Set Part = swApp.ActiveDoc
              Dim FSO As FileSystemObject
              Set FSO = New FileSystemObject
              Dim PathName As String
              PathName = Part.GetPathName
              Dim FileName As String
              FileName = FSO.GetFileName(PathName)
              Dim FileExtension As String
              FileExtension = "." & FSO.GetExtensionName(PathName)
              Dim Name As String
              Name = Mid(FileName, 1, Len(FileName) - Len(FileExtension))
              Debug.Print Name
              Debug.Print "or"
              Name = Replace(FileName, FileExtension, "")
              Debug.Print Name
              Deepak Gupta
              Try this:
              Option Explicit
              Dim swApp                   As SldWorks.SldWorks
              Dim swModel                 As SldWorks.ModelDoc2
              Dim sFileName               As String
              Set swModel = swApp.ActiveDoc
              'Get File Name without extension
              sFileName = Mid(swModel.GetPathName, InStrRev(swModel.GetPathName, "\") + 1)
              sFileName = Left(sFileName, Len(sFileName) - 7)
              'Add/Set the Custom Property
                    swModel.AddCustomInfo2 "DWG No.", swCustomInfoText, Left(sFileName, 11)
                  Else
                      swModel.CustomInfo("DWG No.") = Left(sFileName, 11)
