2 Replies Latest reply on Sep 29, 2014 6:46 PM by Yong Ning
    How to save as eDrawomg with API?
    Yong Ning
          • Re: How to save as eDrawomg with API?
            Yong Ning
            Thanks your tips
            2010 SolidWorks API Help - Open File Example (VBA)
            http://help.solidworks.com/2010/English/api/sldworksapi/Open_File_Example_VB.htm
            swApp.SetUserPreferenceIntegerValue swEdrawingsSaveAsSelectionOption, swEdrawingSaveAll
            swUserPreferenceIntegerValue_e→swEdrawingsSaveAsSelectionOption→
            swEdrawingSaveAsOption_e
              *********a***    swEdrawingSaveActive \\Publish the active configuration or sheet when saving as an eDrawings
              *********b***    swEdrawingSaveAll \\Publish all configurations or sheets when saving as an eDrawings
              *********c***    swEdrawingSaveSelected \\Publish sheets or configurations specified by swEmodelSelectionList when saving as an eDrawings
            swModel.Extension.SaveAs sFileName, swSaveAsCurrentVersion, swSaveAsOptions_Silent, Nothing, nErrors, nWarnings
            Private Sub SaveEdrawing()
              Dim T: T = Timer
              Dim Path, FileName, Filter
              Dim sFileName As String, nErrors As Long, nWarnings As Long
              Dim fileConfig As String, fileDispName As String, fileOptions As Long
              Dim swApp As SldWorks.SldWorks, swModel As ModelDoc2
                Set swApp = GetObject(, "SldWorks.Application")
                Filter = "SolidWorks Files (*.sldprt, *.sldasm, *.slddrw)|*.sldprt,*.sldasm,*.slddrw|Filter name (*.fil)|*.fil|All Files (*.*)|*.*|"
                FileName = swApp.GetOpenFileName("File to Attach", "", Filter, fileOptions, fileConfig, fileDispName)
                Set swModel = SwOpenFile(swApp, FileName)
                sFileName = Left(swModel.GetPathName, Len(swModel.GetPathName) - 6)
                ' Get type of model document and set edrawing extension
                If swModel.GetType = swDocPART Then
                   sFileName = sFileName & "eprt"
                ElseIf swModel.GetType = swDocASSEMBLY Then
                   sFileName = sFileName & "easm"
                ElseIf swModel.GetType = swDocDRAWING Then
                   sFileName = sFileName & "edrw"
                Else
                   Exit Sub
                Debug.Print swModel.GetTitle
                Stop
                Stop
                swModel.SaveAs
              Timing T
            Private Sub ll()
              Dim SwDraw As DrawingDoc
                Set SwDraw = Application.SldWorks.ActiveDoc
                Dim Path: Path = SwDraw.GetPathName
                Path = Left(Path, InStrRev(Path, "\"))
              Dim PathName
                PathName = Path & "aa" & ".SldDrw"
                SwDraw.SaveAs2 PathName, 0, False, False
                PathName = Path & "aa" & ".PDF"
                SwDraw.SaveAs2 PathName, 0, True, False
