I want solidworks to automaticly create a little hole at eacht end of my bend line. How can i do this?
gr mathijs
You need to set the "Bend Relief" parameter in your bends.
Thanks, but when I set auto relief to tear, nothing changes in my drawing.
Basically called as notch, SW doesn't have this option, so better create a library feature for that and add on each end of bending line.
As Ian mentioned there are the options you can set for the bend reliefs. Tear is one of them and rectangular and obround are also supported, they work very well for me. I usually set the width and depth rather than use the default parameters.
