Hi
I want to create a table hole only done with the hole wizard command, is it possible?
Thank
Sorry, I'm not understanding. Can you explain better or show images of what you are wanting?
according to the image, I wanted the hole table only showing the holes inside the red circle, but when I create the table is included other characteristics that are in the green circle, I do not want this information on the table.
You can create this table the way I need?
Thank you
You could delete the rows in the table which refer to the unwanted holes.
-or-
You could select only the edges of the holes you want when creating the table.
You could split the face of the part so that only the wanted holes are selected when selecting the face for the Hole Table.
I imagined it would be something, I thought it might have some command to automate this procedure.
-or-
-or-
