SW2012SP5
Folks,
When I generate a mirrored part by selecting a plane within a part, and then selecting Insert/Mirror Part, my default templates are not being used, I only have one pointer in the file locations for documents, which is located on our server.
I haven't seen this in awhile, it used to pick up are default templates when I mirrored parts.
Anyu ideas what I am not doing correctly?
Ask away!
Brian
Do you've the template path set under Tools > Options > Default Templates. If yes then make sure "Always use these default document templates" is selected.
