What is uncorrect in this simulation?
what problem are you running into?
what have you tried to fix it so far?
what is the goal of the analysis and what type of analysis are you trying to run?
cross post
https://forum.solidworks.com/thread/83161?tstart=0
Well, just try to make the analysis and you will get an error.
My question is what is not defined correctly? is is a definition problem or a SW problem?
I'm trying a static analisys with penetration.
Please, try to open the file and run the solver.
Sorry, just haven't had a chance to take a look.
Have you tried the analysis bonded? Does it run? If so you could slowly start removing the bonding until you find the one that makes it unstable.
looked at your model
there are 2 studies
neither look complete
part of your problem is there are no fixtures
the second if you go bonded only, it should work (if you add a fixture) but if you go no penetration, it will likely have stability problems
what is the goal of your analysis?
