Is it possible to take several parts from one assembly and separate them into a sub-assembly so they can easily be used other assemblies?
An intern created an assembly of PCBs, Heatsink and fans for me. I then built a case around it and, stupidly, saved it in the same file. Now I want to use the initial assembly in an alternate case design.
I know I could just make a copy in a different folder and delete what I don't want to get back to original.
What I'm asking is, can I highlight those parts of the assembly I want to use and pull them out as a group to save under another name.
jerry
Ctrl select parts from the tree, right-click, and choose "Form new sub-assembly here". That creates a virtual sub-assembly that you can then save as an external file.
