9 Replies Latest reply on Jul 2, 2014 10:24 PM by Gabriel Lorenzo Yangzon
    C# Select top and bottom face
      Hi guys
      I have some problem selecting the top and bottom face of a rectangle
      Is there anyway I can select only the top and bottom face of an object ?
      heres my code:
      ModelDoc2 swDoc = ((ModelDoc2)(swApp.ActiveDoc));
                  bool boolstatus = false;
                  int i = 0;
                  int ctr = 0;
                  Feature ft = null;
                  SelectionMgr swSelmgr = swDoc.SelectionManager;
                  SelectData swSelData = (SelectData)swSelmgr.CreateSelectData();
                  boolstatus = swDoc.Extension.SelectByID2("Thicken1", "BODYFEATURE", 0, 0, 0, false, 0, null, 0);
                  Feature feat = swSelmgr.GetSelectedObject6(1,-1);
                  object[] objFace = feat.GetFaces();
                  foreach (Face fce in objFace)
                      ctr++;
                      Entity swEntity = (Entity)fce;
                      swEntity.Select2(false, 1);
                      swDoc.ViewZoomToSelection();
                      ft = swDoc.FeatureManager.InsertMoveFace2(0, true, 0, 0.7, 0, 0);
      thanks
      Gab
          • Re: C# Select top and bottom face
            Sean Phillips
            If your face is always flat. Why not check the normal direction. Normal Property (IFace2)
                thank you for the reply
                how can I code that
                object[]objj =  fce.Normal();
                if( ???)
                    Sean Phillips
                    its an array of doubles.
                    top face will look like this
                    Normal = (-0, 1, -0)
                    bottom face will look like this
                    Normal = (-0, -1, -0)
                    that is if your faces are parallel to the origin cords
                        Dim swApp               As SldWorks.SldWorks
                        Dim swModel             As SldWorks.ModelDoc2
                        Dim swSelMgr            As SldWorks.SelectionMgr
                        Dim swFace              As SldWorks.Face2
                        Dim vNorm               As Variant
                        Set swModel = swApp.ActiveDoc
                        Set swFace = swSelMgr.GetSelectedObject5(1)
                       vNorm = swFace.Normal
                       Debug.Print "Normal = (" & vNorm(0) & ", " & vNorm(1) & ", " & vNorm(2) & ")"
                        hmmm thank you for the information,
                        i can now select the top
                        but
                        can you help me this one my bottom part sometimes not parallel to origin coords  sometimes it shape is square extrude but there is a special case like " J " shape extrude.
                        thanks
                        gab
                            Sean Phillips
                            can you attach a picture of the J shape part?
                                    Sean Phillips
                                    'this should select the most bottom pointing face.
                                    'Cheers,
                                    'Sean Phillips
                                        Dim swFace              As SldWorks.face2
                                        Dim bodies As Variant
                                        Dim partdoc As partdoc
                                        Set partdoc = swModel
                                        bodies = partdoc.GetBodies2(SwConst.swBodyType_e.swSolidBody, True)
                                        Dim body As Body2
                                        Dim i As Integer
                                        Dim holdface As face2
                                        For i = 0 To UBound(bodies)
                                        Set body = bodies(i)
                                        Dim Face As face2
                                        Dim faces As Variant
                                        faces = body.GetFaces
                                        Dim j As Integer
                                        For j = 0 To UBound(faces)
                                            Set Face = faces(j)
                                            Dim face2 As face2
                                            Dim cords1 As Variant
                                            cords1 = Face.Normal
                                            Dim k As Integer
                                            For k = 0 To UBound(faces)
                                                Set face2 = faces(k)
                                                Dim cords2 As Variant
                                                cords2 = face2.Normal
                                                If cords2(1) < cords1(1) Then
                                                    Set holdface = face2
                                            Next
                                        Next
                                        Next
                                        swSelMgr.AddSelectionListObject holdface, Nothing
