Hi there,
I am running an assembly simulation. Initially, I used a globally bonded contact for my assembly - and the simulation was succesful as expected. Now, the only thing I altered was a no penetration contact set between two bodies. I know that local contact sets will override the global contact - so I know that my contact sets are valid. The ONLY thing I changed was switching from a bonded contact, to a no pentratino contact. Understand that where I applied this setting I am using a bolted connection - therefore solidworks requires a no penetration contact between those two faces. Now when I try to run the study, the solver will never finish the simulation. I will usually be prompted with "Cannot create master control file" or more recently "solver encountered numerical difficulties". I have no idea why this is happening. The study will run for well over an hour before I prompt with anything.
If it makes my question easier to answer, I using a curvature based mesh (relatively coarse for a good baseline study) with a max size of 15mm, min size of 3mm(more of less, cant remember), # of tetrahedrons per hole of 10, and a growth ratio of 1.3 I have no issues meshing the assembly.
Please help!
Thank you!
Can you post your model?
