1 Reply Latest reply on Jul 2, 2014 9:44 AM by Sushil Chaskar
    Getting 3d intersection curves..
    Sushil Chaskar
      Hii..I am trying to get 3d intersection curves for number of planes.. For this, first I am selecting all faces of model, then getting plane count and then creating 3d intersections for each plane.. But i am able to create only one sketch .. Any thoughts..?
      Option Explicit
      Dim swSelData As SldWorks.SelectData
      Dim swBody As SldWorks.Body2
      Dim swFace As SldWorks.Face
      Dim swEnt As SldWorks.Entity
      Dim bRet As Boolean
      Dim vBodies As Variant
      Dim boolstatus As Boolean
      Set swModel = swApp.ActiveDoc
      Set swPart = swModel
      Set swSelData = swSelMgr.CreateSelectData
      vBodies = swPart.GetBodies2(swAllBodies, True)
      Set swBody = vBodies(0)
      Set swFace = swBody.GetFirstFace
      swModel.ClearSelection2 True
      Do While Not swFace Is Nothing
      Set swEnt = swFace
      ' Select through Entity
      bRet = swEnt.Select4(True, swSelData): Debug.Assert bRet
      Set swFace = swFace.GetNextFace
      Loop
      Dim Count As Integer
      Count = 0
      Dim swfeature As SldWorks.Feature
      Set swfeature = swModel.FirstFeature
      While Not swfeature Is Nothing
      If swfeature.GetTypeName = "RefPlane" Then
      swfeature.Select2 True, 0
      Count = Count + 1
      Set swfeature = swfeature.GetNextFeature
      Wend
      MsgBox Count
      Dim i As Integer
      For i = 1 To Count - 1
      boolstatus = swModel.Extension.SelectByID2("Plane" & i, "PLANE", 0, 0, 0, False, 0, Nothing, 0)
      swModel.SketchManager.InsertSketch True
      swModel.Sketch3DIntersections
      boolstatus = swModel.Extension.SelectByID2("WEB datum-2", "SURFACEBODY", 0, 0, 0, True, 0, Nothing, 0)
      boolstatus = swModel.Extension.SelectByID2("Imported1", "SOLIDBODY", 0, 0, 0, True, 0, Nothing, 0)
      Next i
