1 Reply Latest reply on Dec 27, 2014 11:00 AM by Yong Ning
    How to get view name from BOM?
    Yong Ning
      Hope get view name from BOM.
      but follow code → get sheet name from BOM.
      Folloe code, can get sheet name,but don't get view name
      method is SwAnn.Owner
      Sub ll()
        Dim SwApp As SldWorks.SldWorks, SwDraw As DrawingDoc
          Set SwApp = Application.SldWorks
          Set SwDraw = SwApp.ActiveDoc
        Dim SwSelMgr As SelectionMgr, SwView As View, SwSheet As Sheet
          Set SwSelMgr = SwDraw.SelectionManager
        Dim SwBomFeat As BomFeature
          Set SwBomFeat = SwSelMgr.GetSelectedObject5(1)
          Debug.Print SwBomFeat.GetFeature.Name
        Dim SwTabAnn As TableAnnotation, SwAnn As Annotation
          Set SwTabAnn = SwBomFeat.GetTableAnnotations(0)
          Set SwAnn = SwTabAnn.GetAnnotation
          Debug.Print SwAnn.GetName, SwAnn.OwnerType
          Debug.Print SwTabAnn.Title
          Set SwSheet = SwAnn.Owner
          Debug.Print SwSheet.GetName
          Debug.Print
      code from
      SolidWorks Forums: Get Sheet Name that BOM is on
      https://forum.solidworks.com/message/436330#436330
      SolidWorks Forums: Macro to delete BOM
      https://forum.solidworks.com/message/415225#415225
        • Re: How to get view name from BOM?
          Yong Ning
          2012-8-27  Artem Taturevych  tips
          How to get →
          SwAnn.OwnerType = swAnnotationOwner_e.swAnnotationOwner_DrawingView  ????
              If SwAnn.OwnerType = swAnnotationOwner_e.swAnnotationOwner_DrawingSheet Then
              ElseIf SwAnn.OwnerType = swAnnotationOwner_e.swAnnotationOwner_DrawingView Then
                  Dim SwView As SldWorks.View
                  Set SwView = SwAnn.Owner
                  Set SwSheet = SwView.Sheet
          'Created by Artem Taturevych (Intercad, Australia)
          'http://intercad.com.au/
          'Disclamer: The API examples are provided as is and should be used as reference only.
          'In no event shall Intercad be liable for any types of damages whatsoever
          '(including without limitation, damages from the loss of use, data, profits, or business)
          'arising out of the uses of this information, applications, or services.
          Const TABLE_NAME As String = "Bill of Materials1"
          Dim swFeat As SldWorks.Feature
              Set swModel = SwApp.ActiveDoc
              Set SwSelMgr = swModel.SelectionManager
              Set swFeat = swModel.FeatureByName(TABLE_NAME)
              If swFeat Is Nothing Then
                  MsgBox "Specified feature does not exist"
                  End
              Dim SwBomFeat As SldWorks.BomFeature
              Set SwBomFeat = swFeat.GetSpecificFeature2
              Dim swTableAnn As SldWorks.TableAnnotation
              Set swTableAnn = SwBomFeat.GetTableAnnotations()(0)
              Dim SwSheet As SldWorks.Sheet
              Set SwSheet = GetTableSheet(swTableAnn)
              If Not SwSheet Is Nothing Then
              Else
                  MsgBox "Error"
          Function GetTableSheet(swTableAnn As SldWorks.TableAnnotation) As Sheet
              Dim SwAnn As SldWorks.Annotation
              Set SwAnn = swTableAnn.GetAnnotation()
              Set GetTableSheet = SwSheet
          End Function
          Private Const strApp As String = "Link2BOM v1.00"
          Public Sub subMain()
              Dim iCnt, iTotal As Integer
              Dim retVal As Variant
              Dim sBOMname As String
              Dim vSheetNames As Variant
              Dim swView As SldWorks.View
              Dim swSheetView As SldWorks.View
              Dim swDrawing As SldWorks.DrawingDoc
              Dim swBOM As SldWorks.Feature
              Set swModel = swApp.ActiveDoc
              ' No document loaded error handler
              If swModel Is Nothing Then
                  MsgBox "No document loaded !", vbCritical
                  End
              ElseIf Not swModel.GetType = 3 Then 'When no Drawing
                  MsgBox "This macro is only for a drawing !", vbCritical
                  End
              Set swDrawing = swModel
              Set swFeat = swModel.FirstFeature
              'Get BOM name
              Do While Not swFeat Is Nothing
                  If "BomFeat" = swFeat.GetTypeName Then
                      Set swBOM = SwBomFeat.GetFeature
                      sBOMname = swBOM.Name
                      Exit Do
                  Set swFeat = swFeat.GetNextFeature
              Loop
              vSheetNames = swDrawing.GetSheetNames
              iTotal = UBound(vSheetNames) + 1
              iCnt = 0
              Do While iCnt < iTotal
                  'Set view linked to BOM
                  retVal = swDrawing.ActivateSheet(vSheetNames(iCnt))
                  Set swSheetView = swDrawing.GetFirstView
                  Set swView = swSheetView.GetNextView
                  Do While Not swView Is Nothing
                      retVal = swView.SetKeepLinkedToBOM(True, sBOMname)
                      Debug.Print swView.Name
                      Set swView = swView.GetNextView
                  Loop
                  iCnt = iCnt + 1
              Loop
              retVal = swDrawing.ActivateSheet(vSheetNames(0))
              swApp.SendMsgToUser2 "       Linking is complete...       ", swMbInformation, swMbOk
              Set swApp = Nothing
              Set swModel = Nothing
              Set swDrawing = Nothing
              Set swFeat = Nothing
              Set SwBomFeat = Nothing
              Set swBOM = Nothing
              Set swSheetView = Nothing
              Set swView = Nothing
              End
