5 Replies Latest reply on Jul 1, 2014 2:48 PM by Deepak Gupta
    I need help defining the actions of this code
    Alex Beaulier
      Here's what I have and what i have defined. Everything that I have as #not sure about this is what I don't understand. I want to learn the SolidWorks API code and I don't know what certain definitions and tasks are doing in this macro. The yellow highlighted part is the code. Thanks again for any help.
      Option Explicit   #Not sure yet
      Dim swApp As SldWorks.SldWorks                            #This defines the application as Solidworks
      Dim swModel As SldWorks.ModelDoc2                  #This defines swModel as the Solidworks model document
      Dim swSketchMgr As SldWorks.SketchManager                                 #This defines swSketchMgr as the sketch manager for creating sketches in SolidWorks
      Dim swExcel As Excel.Application                               #This defines swExcel as the Microsoft Excel application
      Dim exSheet As Excel.Worksheet #This defines the excel spreadsheet as the document to use in the macro for exporting numbers for Solidworks to use
      Dim i As Integer                                #This defines i as an integer to use for various tasks
      Dim xpt As Double                           #Not sure about this part yet
      Dim ypt As Double                           #Not sure about this part yet
      Dim zpt As Double #Not sure about this part yet
      Dim xpt1 As Double #Not sure about this part yet
      Dim ypt1 As Double                        #Not sure about this part yet
      Dim zpt1 As Double                        #Not sure about this part yet
      Sub main() #sets apart the definitions from the actual applications procedures or commands
          Set swApp = Application.SldWorks                        #Sets up the application
          Set swModel = swApp.ActiveDoc                          #Prepares to use the active document for the entity to which the properties will act in
          If swModel Is Nothing Then                     #Is a double check procedure to make sure an active document is open for editing
              MsgBox "Please activate a part document before using this macro."                                                 #is a warning from the macro application to the user on why it will not function
              Exit Sub                        #Exits the current set of commands in the macro and returns to an offline state until the user changes the error so the next run will execute the macro properly
          End If                                 #Ends the if command loop
          If swModel.GetType <> 1 Then                             #Not sure
          End If                 #Ends the If command loop
           If Not swModel.GetActiveSketch2 Is Nothing Then                                    #Not sure yet
              MsgBox "Please exit the sketch before running this macro."                               #is a warning from the macro application to the user on why it will not function
                                      #Code has passed the initial tests. Will start the next commands for the macro
          Set swExcel = GetObject(, "Excel.Application")                              #Will open up the excel application for the macro
          Set exSheet = swExcel.ActiveSheet                                     #Takes the activesheet for importing data
          Set swSketchMgr = swModel.SketchManager                                #Sets the sketch manager open in Solidworks
          swModel.ClearSelection2 True                                              #Clears any selection the mouse is clicked on
          swModel.SketchManager.Insert3DSketch True             #Is activating the 3D sketch for Solidworks
          swModel.SetAddToDB True                                                    #Not sure yet
      i = 1        #Defines the integer i as 1
            Do While exSheet.Cells(i, 1).Value <> ""                          #Not sure yet
              xpt = exSheet.Cells(i, 1).Value / 1000                              #Takes the excel spreadsheet i-A and divides its value by 1000 for the x1-point
              ypt = exSheet.Cells(i, 2).Value / 1000                              #Takes the excel spreadsheet i-B and divides its value by 1000 for the y1-point
              zpt = exSheet.Cells(i, 3).Value / 1000                              #Takes the excel spreadsheet i-C and divides its value by 1000 for the z1-point
              xpt1 = exSheet.Cells(i, 4).Value / 1000                           #Takes the excel spreadsheet i-D and divides its value by 1000 for the x2-point
              ypt1 = exSheet.Cells(i, 5).Value / 1000                           #Takes the excel spreadsheet i-E and divides its value by 1000 for the y2-point
              zpt1 = exSheet.Cells(i, 6).Value / 1000                            #Takes the excel spreadsheet i-F and divides its value by 1000 for the z2-point
              swModel.SketchManager.CreateLine xpt, ypt, zpt, xpt1, ypt1, zpt1                                 #Creates a line based on the values from the above commands
      i = i + 1                                  #defines the next i value as i+1 so the next column will be selected as 2-A 2-B ect
      Loop                                      #defines the loop so the command starts again at i=current value at end of the loop when 1 is added from the previous step
          swModel.ViewZoomtofit2                       #Zooms the Solidwork application to fit the view of all the line segments drawn
          swModel.SetAddToDB False                  #Not sure yet
          swModel.ClearSelection                           #Clears the selection manager from the current operation
          swModel.SketchManager.Insert3DSketch True                             #Not quite sure yet
          swModel.ClearSelection2 True                              #Clears the selection manager
      End Sub                                #Ends the macro
        • Re: I need help defining the actions of this code
          Jason Kerns
          Hello!
          For the data types you can find the Visual Basic Reference or help to understand.
          Data type
          Storage size
          Range
          Byte
          1 byte
          0 to 255
          Boolean
          2 bytes
          True or False
          Integer
          2 bytes
          -32,768 to 32,767
          Long
          (long integer)
          4 bytes
          -2,147,483,648 to 2,147,483,647
          LongPtr
          (Long integer on 32-bit systems, LongLong integer on 64-bit systems)
          4-bytes on 32-bit systems, 8-bytes on 64-bit systems.
          -2,147,483,648 to 2,147,483,647 on 32-bit systems, -9,223,372,036,854,775,808 to 9,223,372,036,854,775,807 on 64-bit systems.
          LongLong
          (LongLong integer)
          8 bytes
          -9,223,372,036,854,775,808 to 9,223,372,036,854,775,807 (Valid on 64-bit platforms only.)
          Single
          (single-precision floating-point)
          4 bytes
          -3.402823E38 to -1.401298E-45 for negative values; 1.401298E-45 to 3.402823E38 for positive values
          Double
          (double-precision floating-point)
          8 bytes
          -1.79769313486231E308 to
          -4.94065645841247E-324 for negative values; 4.94065645841247E-324 to 1.79769313486232E308 for positive values
          Currency
          (scaled integer)
          8 bytes
          -922,337,203,685,477.5808 to 922,337,203,685,477.5807
          Decimal
          14 bytes
          +/-79,228,162,514,264,337,593,543,950,335 with no decimal point;
          +/-7.9228162514264337593543950335 with 28 places to the right of the decimal; smallest non-zero number is
          +/-0.0000000000000000000000000001
          Date
          8 bytes
          January 1, 100 to December 31, 9999
          Object
          4 bytes
          Any Object reference
          String
          (variable-length)
          10 bytes + string length
          0 to approximately 2 billion
          String
          (fixed-length)
          Length of string
          1 to approximately 65,400
          Variant
          (with numbers)
          16 bytes
          Any numeric value up to the range of a Double
          Variant
          (with characters)
          22 bytes + string length
          Same range as for variable-length String
          User-defined
          (using Type)
            Deepak Gupta
            Option Explicit   Forces explicit declaration of all variables in a file, or allows implicit declarations of variables.
               If swModel.GetType <> 1 Then                       Check if the active file is a part file. 1 = Part, 2 = Assembly and 3 = Drawing
            swModel.SketchManager.Insert3DSketch True Start a 3d sketch
                 If Not swModel.GetActiveSketch2 Is Nothing Then       Checks if there is any active sketch
                swModel.SetAddToDB True                                           Sets/Start to add sketch entities to the SolidWorks database, For e.g. if you're making a rectangle then
        you need to have co-ordinates of four corner points
                  Do While exSheet.Cells(i, 1).Value <> ""                      will keep  processing the excel row until a cell in the specified row/column is empty
                swModel.SetAddToDB False                                           End the process of adding sketch entities to the SolidWorks database
                swModel.SketchManager.Insert3DSketch True                Ends the 3d sketch
