I've run into another configuration issue that I can't seem to solve. I have a configured part (a washer) that has a number of configurations. I've recently renamed all the configurations (previous format 00000-000, new format 0.0000 AAA), but when I try to insert it into an assembly, the old configurations still show up as options on insert. Once inserted, if you manually try to re-configure it after inserting it, the name shows up correct.
I'm hoping someone else can try this to see if they have the same problem. Perhaps there is somewhere else to update this information? I've attached the file in question. I'm on Solidworks 2014.
