6 Replies Latest reply on Jul 27, 2015 9:33 AM by Anand Dharwa
    Delete dangling dimensions
    Rafi Sokol
      I need a procedure to delete all dangling dimensions in all the views of an active drawing.
        • Re: Delete dangling dimensions
          Deepak Gupta
          Check swDim.IsDangling
              Rafi Sokol
              This is correct, but how do I collect all the dimensions, to find out which are dangling?
                  Adam Hoffman
                  This is one I wrote for myself to do notes and dimensions. Edit however you like:
                  '                            Clean Up Drawing Macro                              '
                  'Macro will traverse through all drawing views
                  'and delete dangling dimensions and notes
                  'Written by Adam Hoffman
                  'Was written using SolidWorks 2014 SP 2.0
                  'This macro is provided as is and the creator is not responsible for any mishaps
                  Dim swView As SldWorks.View
                  Dim swAnno As SldWorks.Annotation
                  Dim sAnnoType As String
                  Dim swNote As SldWorks.Note
                  Dim bSelect As Boolean
                  Dim bDeleteFlag As Boolean
                  Dim sItemName As String
                  Const swDrawingDoc = 3
                  Const swAssemblyDoc = 2
                  Const swPartDoc = 1
                  Sub CleanUpMain()
                  Set swModel = swApp.ActiveDoc
                  'If the active document is not a drawing exit program
                  If Not swModel.GetType() = swDrawingDoc Then
                     MsgBox ("You Must Run This Macro Inside Of A Drawing!")
                     Exit Sub
                  ElseIf swModel.GetType() = swDrawingDoc Then
                     Set swDraw = swModel
                  swModel.ClearSelection2 (True) 'Make sure all selections are cleared before you start
                  bDeleteFlag = False
                  Set swView = swDraw.GetFirstView 'This is the overall drawing itself
                  Set swView = swView.GetNextView 'This is the actual first view in the drawing
                  'Start the loop through views in the drawing
                  Do While Not swView Is Nothing
                     'Start the dangling Note removal
                     Set swNote = swView.GetFirstNote
                     Do While Not swNote Is Nothing
                        sItemName = ""
                        sItemName = swNote.GetName()
                        Dim sNoteText As String
                        sNoteText = ""
                        sNoteText = swNote.GetText()
                        'I found when dealing with notes this was more reliable
                        'than using the swAnno.IsDangling method
                        If sNoteText = "?" Or sNoteText = "" Then
                           bSelect = swModel.Extension.SelectByID2(sItemName + "@" + CStr(swView.Name), "NOTE", 0, 0, 0, True, 0, Nothing, 0)
                           bDeleteFlag = True
                        Set swNote = swNote.GetNext
                     Loop
                     If bDeleteFlag = True Then
                        'After going through all the notes in this view delete the ones that have been selected
                        boolstatus = swModel.Extension.DeleteSelection2(2)
                     'End of dangling Note removal
                     bDeleteFlag = False
                     boolstatus = False
                     'Start the dangling dimension removal
                     Set swAnno = swView.GetFirstAnnotation3()
                     Do While Not swAnno Is Nothing
                       If swAnno.GetType = 4 Then
                           sItemName = ""
                           If swAnno.IsDangling Then
                              sItemName = swAnno.GetName()
                              bSelect = swModel.Extension.SelectByID2(sItemName + "@" + CStr(swView.Name), "DIMENSION", 0, 0, 0, True, 0, Nothing, 0)
                              bDeleteFlag = True
                        Set swAnno = swAnno.GetNext3()
                     Loop
                        'After going through all the dimensions in this view delete the ones that have been selected
                     'End of dangling dimension removal
                  Loop 'End of loop through drawing views and overall program
