The macro is to open all drawings for the active assembly (sub-assemblies and parts) and save them as individual PDFs. However, the macro doesn't work. Here is the code (which needs to run on a SW 2014, 64-bit system):
Any help would be greatly appreciated!
Thanks!
' Description:
' Traverses the open assembly and activates all components and their drawings (if of the
' same name).
Sub ShowAllOpenFiles()
Dim swDoc As SldWorks.ModelDoc2
Dim swAllDocs As EnumDocuments2
Dim FirstDoc As SldWorks.ModelDoc2
Dim dummy As Boolean
Dim NumDocsReturned As Long
Dim DocCount As Long
Dim i As Long
Dim sMsg As String
Dim bDocWasVisible As Boolean
Dim OpenWarnings As Long
Dim OpenErrors As Long
Dim DwgPath As String
Dim myDwgDoc As SldWorks.ModelDoc2
Dim drwPathName As String
Dim pdfPathName As String
Dim pdfFolderName As String
Set swAllDocs = swApp.EnumDocuments2
Set FirstDoc = swApp.ActiveDoc
DocCount = 0
swAllDocs.Reset
swAllDocs.Next 1, swDoc, NumDocsReturned
While NumDocsReturned <> 0
bDocWasVisible = swDoc.Visible
'swApp.ActivateDoc swDoc.GetPathName'
DwgPath = swDoc.GetPathName
If (LCase(Right(DwgPath, 3)) <> "drw") And (DwgPath <> "") Then
DwgPath = Left(DwgPath, Len(DwgPath) - 3) & "drw"
Set myDwgDoc = swApp.OpenDoc6(DwgPath, swDocDRAWING, swOpenDocOptions_Silent, "", OpenErrors, OpenWarnings)
If Not myDwgDoc Is Nothing Then
swApp.ActivateDoc myDwgDoc.GetPathName
pdfFolderName = "C:\pdf files\"
Dim fso As Scripting.FileSystemObject
Set fso = CreateObject("Scripting.FileSystemObject")
If (Not fso.FolderExists(pdfFolderName)) Then
MsgBox (pdfFolderName + " does not exist")
Exit Sub
Dim Part As ModelDoc2
Set Part = swApp.ActiveDoc()
'You have a drawing active
drwPathName = Part.GetPathName()
If ("" = drwPathName) Then
' GetPathName() was empty
MsgBox ("This drawing has not been saved yet")
Exit Sub
pdfPathName = fso.BuildPath(pdfFolderName, fso.GetBaseName(drwPathName) + ".pdf")
Part.SaveAs2 pdfPathName, 0, True, False
'MsgBox ("PDF file was created")
swApp.QuitDoc (Part.GetTitle)
Set myDwgDoc = Nothing
DocCount = DocCount + 1
Wend
swApp.ActivateDoc FirstDoc.GetPathName
Here is the updated macro for SW2014
