I have a sheetmetal part with multiple bends of varying degrees. I would like to make a drawing showing a flat blank with the first bend location specified. Then another view with that bend completed and the next bend line shown with a dimension to the edge where the bend would be gauged from. Then another view of those two bends bent, with the next bend line shown and a dimension to the bent edge where the next bend line will be gauged from and so on. I tried a couple different methods with no success. I ended up using Solidworks to generate the various views, then exported the drawing to my 2D software, then added and dimensioned the appropriate bend lines.
You can use Configurations for this. Use the Fold and Unfold features in sequence to show the features as they are performed. Then paste 3 or ? views you need into the drawing and just update the configuration you need to show from the Configuration Manager for that view.
