I think the icon order is by the order the icons were added to the
command manager. You try removing all except for the 1st one, then
add each one until you have the order you want.
Thanks Peter
That works.I noticed I had to do one at a time if I prefered one
lower on the list then another, if that makes sense.In other words
I cleared all except the one I wanted first,then closed the command
manager option box, reopened it ,selected the icons in the order I
wanted and they came out in the order they are on the list.
Scott,
I have no problems changing the order of any icon in the command
manger SW 2006.
To do so, I simply select Tools - Customize and then drag and drop
to create any order I desire. I have never deleted and re-added any
icon to get it in the order I prefer.
Have you tried the drag & drop method?
Sorry for the late response, I'm currently conducting
SolidWorks Training classes.
I am able to reorder/move, delete & add the main icons in the
command manager as I can any icons on any of the toolbars.
...again, this is using SW06 SP5.0
Please note:
To reorder/move, delete or add any icons, you must be in
"customize" mode.
Thanks Eddie,that works!
Just by having the customize dialog box open I can drag any of the
icons in the control area to where I want them.I was trying to move
them before by RMB on the command manager and going to customize
command manager.
Scott & All,
A couple of other notes about toolbar customization:
- If you are in customization mode, you can rearrange any toolbars,
including removal of icons. You do not have to be customizing any
particular toolbar as this is only necessary if you are adding a
specific command or icon to a specific toolbar.
- Any command or icon can be added to any toolbar. As an example, I
do not use the alignment tools much but I do use the "Group"
command, so I took the command from alignment and added it to my
annotation toolbar.
Works for me,
Excellent! I recently started using the command manager
exclusively.It has taken a little getting used to but everything
seems to be less cluttered.After reading your post I added all of
my view icons to the standard views.This eliminated one icon from
the control area.I think I'm starting to like this.Thanks
Scott
I think the icon order is by the order the icons were added to the command manager. You try removing all except for the 1st one, then add each one until you have the order you want.
