I feel sheepish, friends.
While I got the answer to my previous question in here, I made the mistake of tagging something to the end of the question, instead of posting a new question about one of the other issues I was experiencing with the operation. Here's what I need to do:
Definitely see the attached model, but in brief, you'll see a feature in a folder called Gangway, which extrudes at an angle normal to the body it is attached to. I need it to do so for direction 1, but direction 2, I need to extrude the same distance, but I need the extrude to be horizontal without changing the distance of any part of the extrude. Here is a diagram to show what I mean:
I feel silly because I didn't ask the complete question last time, so please pardon me for that... You'll see from the model why direction 1 of the Extruded Boss needs to be up to surface, but I need to have direction 2 go the way the picture shows.
Thanks again for all of your patience, I feel like such a newbie asking all of these questions... and I guess I am, but you have all been so kind!
Again, thank you!
you can select a direction other than normal to the sketch plane for extruding, as defined by a model edge or a sketch segment.
