8 Replies Latest reply on Jun 30, 2014 1:42 PM by Glenn Schroeder
    Changing Hole Wizard Model Item in drawing from Linear to Diametric Dimension
    Craig Rose
      I have a drawing where I have imported Model Items for the dimensions, and have a hole I created with Hole Wizard showing up with a linear dimension for the dimension.  I can switch it to showing the dimension as a radius, although it is still a linear dimension.  Normally if you manually insert a dimension into a drawing as a linear dimension you can right click on it and switch to diametric, but in this case that option does not show up.  Is this because it is a Hole Wizard Dimension? And does anyone know how I can change it so that I can still use the Model Item as the dimension shown in the drawing?
