I am running SolidWorks 2014 SP3 on several machines and since upgrading to SP3 have had some of these machines fail to launch the Build Checker.
Upon launching Build check all appears to work at first but a pop up window opens saying the server is busy and the only way to close this is to CTRL Alt Delete and choose the build checker here.
Anyone else experiencing this or have a solution?
Now solved the problem and posting my own reply in case anyone else has the same answer.
The error told me server busy and would only respond by using the ctrl+alt+del then closing the build check. None of the three buttons at the bottom did anything.
However I persevered and kept clicking on retry and eventually the message would disappear, I clicked on "do not show at startup" on the welcome screen and then close. The server busy pop up occured. I repeated several times and eventually the do not show at startup worked and close goy me in to Build Check area.
I have reopened several times and the error has gone.
