Can I import drawings from a PDF? If so, what are the steps I need to take to do this?
Welcome to SOLIDWORKS forums Carol.
Try Able2Extract PDF to DWG converter. And then you may be able to import the DWG into the SW.
You might also find this post helpful for your future reference.
I do not beleive there is any way to directly import a pdf. What exactly are you trying to do with the pdf....make a part from it, create a drawing?
Chris
