7 Replies Latest reply on Jun 29, 2014 5:34 AM by Deepak Gupta
    How to get the Value / Text Expression?
    Yong Ning
      Help me
      Hope get Value / Text Expression ------- "SW-Mass@@a4@b.SLDASM"
      Value / Text Expression →  "SW-Mass@@a4@b.SLDASM"
      follow code   → don't get Value/Text Expression→ "SW-Mass@@a4@b.SLDASM"
      GetCustomProperties(vPropName, vPropValue, vPropType)→mm <30> = 45.00
      → result is
      vPropName → mm
      vPropValue → 45.00
      vPropType  → 30
      Option Explicit
      Public Enum swCustomInfoType_e
          swCustomInfoUnknown = 0
          swCustomInfoText = 30       '  VT_LPSTR
          swCustomInfoDate = 64       '  VT_FILETIME
          swCustomInfoNumber = 3      '  VT_I4
          swCustomInfoYesOrNo = 11    '  VT_BOOL
      End Enum
          Dim swApp                   As SldWorks.SldWorks
          Dim swModel                 As SldWorks.ModelDoc2
          Dim swConfig                As SldWorks.Configuration
          Dim vConfName               As Variant
          Dim vPropName               As Variant
          Dim vPropValue              As Variant
          Dim vPropType               As Variant
          Dim nNumProp                As Long
          Dim i                       As Long
          Dim j                       As Long
          Dim bRet                    As Boolean
          Set swModel = swApp.ActiveDoc
          Debug.Print "File = " + swModel.GetPathName
          vConfName = swModel.GetConfigurationNames
          For i = 0 To UBound(vConfName)
              Set swConfig = swModel.GetConfigurationByName(vConfName(i))
              nNumProp = swConfig.GetCustomProperties(vPropName, vPropValue, vPropType)
              Debug.Print "  Config       = " & vConfName(i)
              For j = 0 To nNumProp - 1
                  Debug.Print "    " & vPropName(j) & " <" & vPropType(j) & "> = " & vPropValue(j)
              Next j
              Debug.Print "  ---------------------------"
          Next i
      Private Sub Main2()
          Dim SwApp As SldWorks.SldWorks, SwModel As SldWorks.ModelDoc2
          Dim vConfigNameArr, vConfigName
          Dim Str, ii, PrtAsm, Conf
          Set SwApp = Application.SldWorks
          Set SwModel = SwApp.ActiveDoc
          vConfigNameArr = SwModel.GetConfigurationNames
          For ii = 0 To UBound(vConfigNameArr)
              vConfigName = vConfigNameArr(ii)
              With SwModel
                 .ShowConfiguration vConfigName
                 Str = "SW-Mass@@" & vConfigName & "@" & SwModel.GetTitle
                 .AddCustomInfo3 vConfigName, "mm", 30, "12"
                 .CustomInfo2(vConfigName, "mm") = """" & Str & """"
              End With
          Next ii
        • Re: How to get the Value / Text Expression?
          Deepak Gupta
          Your codes worked fine for me for getting the value/text expression.
          For your second code, in order to add the correct expression and get the desired output value, use these codes:
          Sub main2()
              Dim sModelName             As String
              Dim vConfigName            As Variant
              Dim sConfigName            As String
              Dim str                    As String
              Dim i                      As Long
              sModelName = Mid(swModel.GetPathName, InStrRev(swModel.GetPathName, "\") + 1)
              vConfigName = swModel.GetConfigurationNames
               For i = 0 To UBound(vConfigName)
                  sConfigName = vConfigName(i)
                  str = Chr(34) & "SW-Mass@@" & sConfigName & "@" & sModelName & Chr(34)
                  swModel.AddCustomInfo3 sConfigName, "mm", 30, str
              Next i
          If the files extension for known files are set to hidden, then SwModel.GetTitle won't yield the extension and hence the expressions fails.
