Normall a right claick of the material in the part tree material would provide the means to edit the material . After installing 2014, I am unable to perform this task.
Previous resolution require a register value change, however in 2014 the values are not the same. Any thoughts on how to resolve this problem
hei'ya Joseph, welcome the forum,
do you mean it's not on the RMB menu,
have you checked the custom menu,
and toggled "Edit Material"
hope this helps, if not post a scnsht of what is displayed,
or use the advanced editor- top right of the reply pane,
to upload a sample/dummy file so members can check your settings,
use attach files> browse- bottom left of the pane
have a good'n kelef
