Hi All
I have this 3D Object in DWG format from which I would like to create a sheet metal flat pattern for production at our factory.
I imported the DWG file as "3D curves or model" into SW. But from there, I get errors when trying to convert the imported object to sheet metal. After that, I still need to assign bends and unfold it to create the flat pattern. Can anyone give me some general advice on how to get started?
hei'ya Scott, see att.prt file
offset a "0" surface, inside of dish
hide original import,
convert to sheet metal - convert-Solid1 - base as centre piece-
2nd convert to sheet metal - convert-Solid2 - side panels
bend/split as you wish to produce
hope this helps- have a good'n kelef
edit: see dish-one-piece-klf,sldprt, if this is where you want to get to
