99% of the time when I export standard faces to DXF for use in Illustrator for generating a laser cutting file everything works fine. However, it seems that SW's splines act a little funny when imported into Illustrator (see images for eDrawings vs. Illustrator view of the DXF vector paths).
Anyone have a solution to get rid of the loops? I'm working with SW 2012, Win7, Illustrator CS2.
>>> eDrawings
>>> Illustrator
Solved. After a bit of playing, if you export the DXF by right-clicking the "Flatten" feature, it seems to give perfectly smooth lines.
