6 Replies Latest reply on Jun 25, 2014 3:22 PM by Deepak Gupta
    Save Each Sheet As PDF - Help
    Tyler Banschbach
      I am attempting to divide out a drawing file into multiple PDFs based on the sheet names. I found the attached is code and downloaded from 3D content central. I haven't recieved a response yet from the creator so I'm bringing it up to you all. I can't use this code though multiple people on 3D Content Central have used it successfully. When I run it, SW tells me there is an error @ ...
      'declare and set modelDoc object
          Dim swDoc As ModelDoc2
          Set swDoc = swApp.ActiveDoc
      While I am terrible with VBA as of yet I do understand that this code may need some revising for my specific files/filepaths. I am desperately looking for help here. This task will take a great deal of time if I have to do manually so please help ...
      Message was edited by: Tyler Banschbach
        • Re: Save Each Sheet As PDF - Help
          Deepak Gupta
          Which version of SolidWorks you're running this macro on. I think you need to fix the references in the macro.
          To fix libraries, open the macro (Tools > Macro > Edit). Go to references, uncheck the three highlighted libraries in the picture or missing libraries and select same for your version of SolidWorks. Save the macro and run again.
          https://forum.solidworks.com/servlet/JiveServlet/download/353474-96197/Fix%20Library.PNG
          These posts have several more macros (with various output options) if you want to try out:
          https://forum.solidworks.com/message/322155#322155
          https://forum.solidworks.com/message/353413#353413
              Tyler Banschbach
              Hi Deepak,
              I am running 2014 and have checked the boxes as you require for solidworks 2014. The code pasted below has worked spottingly but doesn't do what I want even when it works (though close). Any attempt at modifying it myself has failed thus far so I'm back on here asking for help. What I am needing is for the macro to save each sheet in my file as a pdf under the name: " [file name] [-] [sheet name]" for instance one of the pdfs would save out as ... DGD008050 - Sanded , where DGD008050 is the file name and Sanded is the sheet name. I would love it if somehow the macro new to save the "sanded pdfs" to the specific directory where the folder's name is "Sanded PDFs" and then for the "Non Sanded" sheet names it new to save those pdfs out in the same base directory but the folder's name is "Non Sanded PDFs" and so on and so forth for the rest of the sheets. This is likely to much to ask so instead I am happy with all of the pdfs saving out to an allocated directory where I will create the folders and seperate each pdf into their respective folder manually.
              _________________________________________________________________________________________________________
              Option Explicit
                  'check for valid solidworks application
                  If swApp Is Nothing Then
                      MsgBox "Error Connecting to SolidWorks. Please Try Again.", vbCritical
                      Exit Sub
                  'check for valid document
                  If swDoc Is Nothing Then
                      MsgBox "Unable to Connect to a Valid SolidWorks Drawing.", vbCritical
                      Exit Sub
                  'check for valid drawing
                  If swDoc.GetType <> SwConst.swDocumentTypes_e.swDocDRAWING Then
                      Exit Sub
                  'Declare and set drawing object
                  Dim swDwgDoc As DrawingDoc
                  Set swDwgDoc = swDoc
                  'declare and set exporter object
                  Dim swExporter As SldWorks.ExportPdfData
                  Set swExporter = swApp.GetExportFileData(SwConst.swExportDataFileType_e.swExportPdfData)
                  'declare and set output directory to current path
                  Dim outputPath As String
                  outputPath = getFolderFromFullPath(swDoc.GetPathName)
                  'create and set array for sheet names
                  Dim sheetNames As Variant
                  sheetNames = swDwgDoc.GetSheetNames
                  'create and set object for current sheet
                  Dim CurDwgSheet As Sheet
                  Set CurDwgSheet = swDwgDoc.GetCurrentSheet
                  'create base out name
                  Dim outputFileName As String
                  outputFileName = getTitleFromFullTitle(swDoc.GetTitle, CurDwgSheet.GetName)
                  'errors and warnings objects
                  Dim lErrors As Long
                  Dim lWarnings As Long
                  Dim i As Integer
                  Dim bRet As Boolean
                  'create frame and status bar pane object
                  Dim statusPane As StatusBarPane
                  Dim swFrame As SldWorks.Frame
                  Set swFrame = swApp.Frame
                  Set statusPane = swFrame.GetStatusBarPane
                  statusPane.Visible = True
                  'loop through and export each sheet
                  For i = 0 To UBound(sheetNames)
                      'update status pane
                      statusPane.Text = "Exporting " + sheetNames(i)
                      'update exporter object
                      bRet = swExporter.SetSheets(SwConst.swExportDataSheetsToExport_e.swExportData_ExportSpecifiedSheets, sheetNames(i))
                      'check for errors
                      If bRet = False Then
                          MsgBox "Error Creating PDF on Sheet: " + Str(i)
                          Exit Sub
                      'save out pdf
                      bRet = swDoc.Extension.SaveAs(outputPath + outputFileName + " - " + sheetNames(i) + ".pdf", SwConst.swSaveAsVersion_e.swSaveAsCurrentVersion, SwConst.swSaveAsOptions_e.swSaveAsOptions_Silent, _
                          swExporter, lErrors, lWarnings)
                      'check for errors
                          CatchErrors lErrors
                          Exit Sub
                  Next i
              Private Function getFolderFromFullPath(thefullpath As String) As String
                  'returns the path without the filename
                  getFolderFromFullPath = Strings.Mid(thefullpath, 1, Strings.Len(thefullpath) - ((Strings.Len(thefullpath) - Strings.InStrRev(thefullpath, "\"))))
              End Function
              Private Function getTitleFromFullTitle(thefulltitle As String, thesheetname As String) As String
                  'returns filename without sheet name
                  getTitleFromFullTitle = Strings.Mid(thefulltitle, 1, Strings.Len(thefulltitle) - ((Strings.Len(thefulltitle) - Strings.InStrRev(thefulltitle, thesheetname) + 4)))
              End Function
              Private Sub CatchErrors(theError As Long)
                  Select Case theError
                      Case 0
                      Case SwConst.swFileSaveError_e.swGenericSaveError
                          MsgBox "File Saving Error", vbExclamation
                      Case SwConst.swFileSaveError_e.swReadOnlySaveError
                          MsgBox "File Saving Error: Read-Only Rights", vbExclamation
                      Case SwConst.swFileSaveError_e.swFileNameEmpty
                          MsgBox "File Saving Error: Empty Filename", vbExclamation
                      Case SwConst.swFileSaveError_e.swFileNameContainsAtSign
                          MsgBox "File Saving Error: Invalid FileName Character", vbExclamation
                      Case SwConst.swFileSaveError_e.swFileSaveFormatNotAvailable
                          MsgBox "File Saving Error: Invalid File Format", vbExclamation
                      Case SwConst.swFileSaveError_e.swFileSaveAsNameExceedsMaxPathLength
                          MsgBox "File Saving Error: Filename Exceeds Maximum Path Length of 255 Characters", vbExclamation
                  End Select
                  Tom Bostick
                  I ran it yesterday and had problems until I added the 'Solidworks Utilities 2013 Type Library' reference also.
                  No problems after that.
                      Tyler Banschbach
                      Nobody wants to take a shot at it?
                          Tom Bostick
                          Replace the "save out pdf" section of code with this. If sheet name is "Sanded", "Non Sanded" or other it will go to respective folders or the drawing directory. Sanded/Non Sanded folders are subfolder of the drawing's folder.
                                  'save out pdf
                                  If sheetNames(i) = "Sanded" Then
                                      bRet = swDoc.Extension.SaveAs(outputPath + "Sanded\" + outputFileName + " - " + sheetNames(i) + ".pdf", SwConst.swSaveAsVersion_e.swSaveAsCurrentVersion, SwConst.swSaveAsOptions_e.swSaveAsOptions_Silent, _
                                  ElseIf sheetNames(i) = "Non Sanded" Then
                                      bRet = swDoc.Extension.SaveAs(outputPath + "Non Sanded\" + outputFileName + " - " + sheetNames(i) + ".pdf", SwConst.swSaveAsVersion_e.swSaveAsCurrentVersion, SwConst.swSaveAsOptions_e.swSaveAsOptions_Silent, _
                                  Else
                              Deepak Gupta
                              You can further add some more codes to create Sanded, No-Sanded folder in case they don't exist
                              'save out pdf
                                        'Check/Create Directory
                                      If Dir(outputPath + "Sanded") = "" Then
                                      MkDir outputPath + "Sanded"
                                      Else
                                      If Dir(outputPath + "Non Sanded") = "" Then
                                      MkDir outputPath + "Non Sanded"
                                      Else
                                      Else
