1 Reply Latest reply on Jun 24, 2014 7:12 PM by Artem Taturevych
    API no return for the actual Save() method
    John Laslavic
      API do not return for the actual Save() method
      This is using the SWDocManager API and unfortunately there is no return for the actual Save() method, so you can’t tell if it was successful or not.   No exceptions are thrown if failed.
      The only way I could do it was deleting the original file and doing a swDoc.SaveAs() instead.  I could not reproduce the failed Save() on new PLMWorx files.  Not sure if this helps….
      File.SetAttributes(sDocFileName, FileAttributes.Normal);
      swDoc = (SwDMDocument15)swDocMgr.GetDocument(sDocFileName, nDocType, true, out nRetVal);
      retValTemp = swDoc.AddCustomProperty("PLM_ItemNumber", SwDmCustomInfoType.swDmCustomInfoText, PLM_ItemNumber);
      retValTemp = swDoc.AddCustomProperty("PLM_ItemMajorRevision", SwDmCustomInfoType.swDmCustomInfoText, PLM_ItemMajorRevision);
      retValTemp = swDoc.AddCustomProperty("PLM_ItemMinorRevision", SwDmCustomInfoType.swDmCustomInfoText, PLM_ItemMinorRevision);
      swDoc.Save();
