2 Replies Latest reply on Jun 25, 2014 9:29 AM by Klaudiusz Skiba
    Inserting blocks on different layer
    Klaudiusz Skiba
      In my macro I'm inserting few different blocks. They automatically are inserted on balloon layer on my drawing. I would like those blocks to be not inserted on any layers or in other words the layer would be specified as NONE.
        • Re: Inserting blocks on different layer
          Tom Bostick
          Try this.
          Dim swDwg As SldWorks.DrawingDoc
          Dim swBlkDef As SldWorks.SketchBlockDefinition
          Dim swBlk As SldWorks.SketchBlockInstance
          Dim swSkMgr As SldWorks.SketchManager
          Dim vBlkDef As Variant
          Dim vBlkInst As Variant
          Dim nbrBlks As Integer
          Dim blkLayer As String
          Dim bRet As Boolean
          Dim longWarnings As Long, longStatus As Long
              Set swModel = swApp.ActiveDoc
                  If swModel Is Nothing Then
                      MsgBox "No file open."
                      Exit Sub
                  ElseIf swModel.GetType = swDocDRAWING Then
                      Set swDwg = swModel
              Set swSkMgr = swModel.SketchManager
              vBlkDef = swSkMgr.GetSketchBlockDefinitions
              blkLayer = ""
              If Not IsEmpty(vBlkDef) Then
                  For i = 0 To UBound(vBlkDef)
                      Set swBlkDef = vBlkDef(i)
                      vBlkInst = swBlkDef.GetInstances
                      nbrBlks = swBlkDef.GetInstanceCount
                      If nbrBlks > 0 Then
                          For j = 0 To nbrBlks - 1
                              Set swBlk = vBlkInst(j)
                              swBlk.Layer = blkLayer
                          Next j
                  Next i
              Klaudiusz Skiba
              I didn't try your code because I'm inserting my blocks from files, but simple change of layers before hand and after did the trick.
              Here is a code to change layer before and after inserting anything.
                  Set swSktManager = swModel.SketchManager
                  Set swLayerMgr = swModel.GetLayerManager
                  checkStr = swLayerMgr.GetCurrentLayer
                  checkInt = swLayerMgr.SetCurrentLayer("")   ' layer changed to none or any other specified
                  'do your work here on different layer
                  checkInt = swLayerMgr.SetCurrentLayer(checkStr) ' layer changed back to the original one
