Is there a way to create a keyboard shortcut that goes directly to corner trim OR power trim? Solid Edge has these as separated commands and I miss not having to choose the type of trim I need everytime I start the trim command.
Trim seems to default to power trim when you use it, at least for me, but even in power trim mode you can corner trim by clicking instead of dragging. Click the line you want to trim first then the line you want to trim it to.
Hope this helps!!
Chris
