3 Replies Latest reply on Jun 25, 2014 7:07 AM by Ar K
    Create Plane
    Ar K
      Hi :-)
      I have a sketch with chain of segments (lines,arcs,splines,...)
      I want to create a normal Plane in end point of this sketch automaticly.
      Do you have an idea or answer for this ?
      Please help me :-)
        • Re: Create Plane
          Artem Taturevych
          Try this. Select the spline in the closed sketch before running the macro.
              Set swModel = swApp.ActiveDoc
              Dim swSkSpline As SldWorks.SketchSpline
              Set swSkSpline = swSelMgr.GetSelectedObject6(1, -1)
              Dim vPts As Variant
              vPts = swSkSpline.GetPoints2()
              Dim swStartPt As SldWorks.SketchPoint
              Dim swEndPt As SldWorks.SketchPoint
              Set swStartPt = vPts(0)
              Set swEndPt = vPts(UBound(vPts))
              CreatePlane swStartPt, swSkSpline
              CreatePlane swEndPt, swSkSpline
          Sub CreatePlane(skPoint As SldWorks.SketchPoint, skSeg As SldWorks.SketchSegment)
              swModel.ClearSelection2 True
              skPoint.Select4 True, Nothing
              swSelMgr.SetSelectedObjectMark 1, 0, swSelectionMarkAction_e.swSelectionMarkSet
              skSeg.Select4 True, Nothing
              swSelMgr.SetSelectedObjectMark 2, 1, swSelectionMarkAction_e.swSelectionMarkSet
              swModel.FeatureManager.InsertRefPlane _
                  swRefPlaneReferenceConstraints_e.swRefPlaneReferenceConstraint_Coincident, 0, _
                  swRefPlaneReferenceConstraints_e.swRefPlaneReferenceConstraint_Perpendicular, 0, _
                  0, 0
          ______________________________________________
          Regards, Artem Taturevych | Snr. Developer | IC3D ANZ
          IC3DSteel – New Steel Solution for SolidWorks
          LinkedIn - SolidWorks API Group
            • Re: Create Plane
              Ar K
              Thank you ,
              But attached pic was an example !!
              I just know , i have a sketch which has some segments
              I do not know end segment is line or arc or spline !!
              this sketch draw by user !!!
              now i want create a normal plane in end of path of sketch.
            • Re: Create Plane
              Ar K
              Option Explicit
              Dim swApp As Object
              Dim swModel As ModelDoc2
              Dim swPart As PartDoc
              Dim swSelMgr As SelectionMgr
              Dim swFeat As Feature
              Dim swSketch As Sketch
              Dim vSkContours() As Object
              Dim skContour As SketchContour
              Dim vSkSegments() As Object
              Dim skSegment As SketchSegment
              Dim skSegType As Long
              Dim swEndPt As SketchPoint
              Dim swSkLine As SketchLine
              Dim swSkArc As SketchArc
              Dim swSkSpline As SketchSpline
              Dim i, j As Integer
              Set swPart = swModel
              Set swFeat = swPart.FeatureByName("Sketch1")
              Set swSketch = swFeat.GetSpecificFeature2()
              '             or
              'Set swSketch = swModel.GetActiveSketch2()
              'Set swFeature = swSketch
              If Not swSketch Is Nothing Then
                         vSkContours = swSketch.GetSketchContours()
                          For i = LBound(vSkContours) To UBound(vSkContours)
                              Set skContour = vSkContours(i)
                              If Not skContour Is Nothing Then
                                  vSkSegments = skContour.GetSketchSegments()
                                  j = UBound(vSkSegments)
                                  Set skSegment = vSkSegments(j)
                                  If Not skSegment Is Nothing Then
                                      skSegType = skSegment.GetType()
                                      Select Case skSegType
                                          Case swSketchSegments_e.swSketchLINE
                                             Set swSkLine = skSegment
                                             Set swEndPt = swSkLine.GetEndPoint2()
                                             Call CreatePlane(swModel, swSelMgr, swEndPt, skSegment)
                                          Case swSketchSegments_e.swSketchARC
                                              Set swSkArc = skSegment
                                              Set swEndPt = swSkArc.GetEndPoint2()
                                          Case swSketchSegments_e.swSketchSPLINE
                                              Set swSkSpline = skSegment
                                              Dim vPts() As Object
                                          Case Else
                                      End Select
                          Next i
              Sub CreatePlane( _
                                           swModel As ModelDoc2, swSelMgr As SelectionMgr, _
                                           skPoint As SketchPoint, skSeg As SketchSegment)
                       swRefPlaneReferenceConstraints_e.swRefPlaneReferenceConstraint_Perpendicular, 0, 0, 0
              With Special Thanks to Artem Taturevych :-)
