:::::Hi Guys::::
<^ Please Open the Part Attached
I am unsucessfully trying to Run FEA on a Wheel Chair to see if it can hold a 300lb Person ( 300lb is 1320 N Y-Asix/Downwards force)
I am running a Static Study
I need to run Convergance Test as well
I tired Meshing;::
All Three:
a) Course
b)Medium
c)Fine
I get Mirror3 Errors
So i checked All my MIRRORS and redid along the RIGHT PLANE
Still get the sme error for all changes that I could possibly come up with
can anyone please take a look at the part and Run FEA Analysis for me/Help ME get past this
if you know how
I added as much details as i could
Thank You for all your help guys
Cadster,
You're more likely to get a good response in the SolidWorks Simulation/Simulation forum.
I didn't open your part (not enough time and still running SW2010). I see that you have the Convert Entities warning, which I assume means that one of your sketches has some issues. If your parts are bad, getting a good simulation gets evern harder.
For a first pass at the analysis you should use symmetry and just model half of the wheel chair. Everything will go much faster. Since it looks like your mesh error is on a mirrored part, not mirroring may fix that problem. (Or it might be that SolidWorks just found the problem first on the mirrored part and will fail the same on the orginal part.)
Is the chair built up out of tubing? If so, you will have lots of problems trying to get it to solve if you are using solid elements, as the mesh size should be small enough to give a couple of elements through the wall of the tube. Shell elements would be better, since the elements can be much larger. Beam elements would solve the fastest, but I don't know who well they would work for the curved tubes. Best to ask the guys in the Simulation forum.
Jerry S.
