AMAbhijeet Mitra21/06/2014
I need to modify a part which was been made by using sweep command < profile through a guide curve>. Guide cuve length was controled by using 'path length dimension', now I need to modify some sketch relations for which it is required to remove the path command which I am unable to do. Can sombody suggest the way to de-select the curves or remove the path dimension command???????
Abhijeet Mitra
