3 Replies Latest reply on Jun 20, 2014 11:01 AM by Klaudiusz Skiba
    Select a note by its name
    Klaudiusz Skiba
      I'm trying to select notes based on their names. I'm using swModel.Extension.SelectByID2(noteName, "NOTE" , 0, 0, 0,  False, 0, Nothing, 0).
      if I don't put coordinates in it won't pick it up.
        • Re: Select a note by its name
          Simon Turner
          Alternatively, use ModelDoc2.GetFirstAnnotation2 and Annotation.GetNext3 to loop through all annotations until you find the one with the correct name.
              Klaudiusz Skiba
              Thank you for opening my blind sleepy eyes. So simple.
              *Edit.
              Sadly it doesn't work. Solidworks api states:
              For parts and assemblies, this method returns the first IAnnotation object in the model. For drawings, access the annotations using the IView::GetFirstAnnotation3 method.
              So I'm back to square one. Thanks again anyway.
                  Klaudiusz Skiba
                  it is actually picked up by view beacuse sheet is considered a view. both codes work but note is faster
                      While Not (swView Is Nothing)
                          Set swNote = swView.GetFirstNote
                          While Not (swNote Is Nothing)
                              noteName2 = swNote.GetName
                              Debug.Print "8888888*********" & noteName2
                              Set swNote = swNote.GetNext
                          Wend
                          Set swView = swView.GetNextView
                      Wend
                      Set swView = swDraw.GetFirstView
                          Set swAnno = swView.GetFirstAnnotation2()
                          While Not (swAnno Is Nothing)
                              noteName2 = swAnno.GetName
                              Debug.Print "9999999*********" & noteName2
                              Set swAnno = swAnno.GetNext
                          Wend
                      Wend
