3 Replies Latest reply on Jun 23, 2014 12:38 PM by Patrick O'Hern
    problem in mate command
    Vishaldeep Singh
      there is a flat face on to.sldprt i select that face and coincide with point during recording a macro but when i run the macro it is not selecting the right face.
      in image 1 the face is selected that i need but in image 2 the face is selected that is not my requirement
        • Re: problem in mate command
          Deepak Gupta
          From your image 1 it is not clear as which face you want to select via macro.
            Ivana Kolin
            If it is possible change to.SLDPRT so, that flat face is on origin.
            Here is your macro - cleaned up from unnecessary code.
            Option Explicit
            Dim Part As SldWorks.PartDoc
            Dim boolstatus As Boolean
            Set Part = swApp.ActiveDoc
            Dim myFeature As SldWorks.Feature
            Set myFeature = Part.InsertPart2("...<yourpath>.....\wo.SLDPRT", 1109)
            Part.ClearSelection2 True
            Part.SketchManager.Insert3DSketch True
            Dim skPoint As SldWorks.SketchPoint
            Set skPoint = Part.SketchManager.CreatePoint(-0.019544, 0.024943, -0#)
            Dim skSegment As SldWorks.SketchSegment
            Set skSegment = Part.SketchManager.CreateLine(0.0005, 0.0005, -0.0055, -0.045682, -0.052104, -0.0055)
            Part.SetPickMode
            Part.SketchManager.InsertSketch True
            Set myFeature = Part.InsertPart2("...<yourpath>.....\to.SLDPRT", 1109)
            Part.EditRebuild
            Dim Component As SldWorks.Component2
            Dim FeatureData  As SldWorks.MoveCopyBodyFeatureData
            Dim swFeat As SldWorks.Feature
            boolstatus = myFeature.Select2(False, 0)
            Set swFeat = Part.FeatureManager.InsertMoveCopyBody2(0, 0, 0, 0, 0, 0, 0, 0, 0, 0, False, 1)
            Set FeatureData = swFeat.GetDefinition()
            boolstatus = Part.Extension.SelectByID2("Axis1-to", "AXIS", 0, 0, 0, False, 1, Nothing, 0)
            boolstatus = Part.Extension.SelectByID2("Line1@3DSketch1", "EXTSKETCHSEGMENT", 0, 0, 0, True, 1, Nothing, 0)
            FeatureData.AddMate Nothing, 0, 1, 0, 0, longstatus
            boolstatus = Part.Extension.SelectByID2("", "FACE", 0, 0, 0, False, 1, Nothing, 0)
            boolstatus = Part.Extension.SelectByID2("Point1@3DSketch1", "EXTSKETCHPOINT", 0.0005, 0.0005, -0.0055, True, 1, Nothing, 0)
            FeatureData.AddMate Nothing, 0, 2, 0, 0, longstatus
            swFeat.ModifyDefinition FeatureData, Part, Component
              Patrick O'Hern
              Selection using coordinates is very unstable in the API.  Selections will vary depending on zoom level and model rotation.  I'm not really sure what your process is for building the parts, but if you can give your face a name, it will make selection much more reliable.
              To name your face, you can right click on it and select "Face Properties" (may require expanding the menu).  Then you can enter a name in the window.
