Hi All,
I was having trouble trying to do a batchget in EPDM to get the latest version of all files in a directory and I finally figured it out.
Here is the code I was using:
Try
Dim Vault As New EdmVault5
Vault.LoginAuto("Engineering", 0)
Dim SubFolder As String = Vault.RootFolderPath & "\DirectoryToRefresh"
Dim GetDirectory() As EdmSelItem = Nothing
ReDim GetDirectory(0)
GetDirectory(0).mlDocID = 0
GetDirectory(0).mlProjID = Vault.GetFolderFromPath(SubFolder).ID
Dim bg As IEdmBatchGet
bg = Vault.CreateUtility(EdmUtility.EdmUtil_BatchGet)
bg.AddSelection(Vault, GetDirectory)
bg.CreateTree(0, EdmGetCmdFlags.Egcf_Nothing)
bg.GetFiles(0, Nothing)
Catch ex As Runtime.InteropServices.COMException
MessageBox.Show("HRESULT = 0x" + ex.ErrorCode.ToString("X") + vbCrLf + ex.Message)
Catch ex As Exception
MessageBox.Show(ex.Message)
End Try
For the longest time i was getting an "E_INVALIDARG" on the line "bg.AddSelection".
Finally I stumbled accross this page in the API Help Documentation:
http://help.solidworks.com/2014/English/api/epdmapi/Using_NET_Framework_in_Applications.htm
If you are developing in Visual Studio like I was and have a reference set to interop.edmLib you have to do the following:
Go to "My Project" > "References" > Click on PDMWorks Enterprise 20xx Type Library > and set the "Embed Interop Types" to False
Note: This is vaild if you are programming in 4.0 or 4.5! (I was programming in 4.5)
After I changed this value, then bingo, worked like a charm.
Hopefully this will help someone else out!
Cheers,
Ethan
