Working with SW2014 to export a simple explode/collapse sequence to smooth out in MODO and incorporate other objects.
The keyframes in SW2014 don't include any rotations just unidirectional motion from collapsed to final exploded position. When saved out to an lxo file through the motion study panel and opened in MODO several meshes are offset from their original position or rotated.
Has anyone else experienced this? If so is there a fix or procedure you've done to correct it?
Thank you
Can't you just adjust the positions of the effected meshes in modo so they are correct?
