0 Replies Latest reply on Jun 18, 2014 8:12 PM by Alex Beaulier
    Can anyone modify this code for the boundary surface tool with lines?
    Alex Beaulier
      I have a ton of line segments in one sketch for a solidworks part. I need to modify this macro below so I can have the boundary surface tool select every single line from one side to another. All the lines are in order from one side to another. I don't know how to modify the code so instead of curves, it uses linesegments and instead of using the surface loft, it will use the boundary surface.
      Basically, I need a code that will
      *create a boundary surface using line segments from a single sketch
      Thanks!
      Here's the code
      Dim swDoc As SldWorks.ModelDoc2
      Dim swSketch As SldWorks.Sketch
      Dim vSegs As Variant
      Dim vSeg As Variant
      Dim swSeg As SldWorks.SketchSegment
      Dim swModel As Object
          ' Initialize Solidworks objects
          Set swDoc = swApp.ActiveDoc
          Set swSketch = swDoc.SketchManager.ActiveSketch
          Set swModel = swApp.ActiveDoc
          ' Throw an error & exit if not in sketch
          If swSketch Is Nothing Then
              MsgBox "No sketch active!"
              Exit Sub
          ' Clear selection & get segments from sketch
          swDoc.ClearSelection2 True
          vSegs = swSketch.GetSketchSegments
          ' Create points from beginnings of spline curves
          Dim Curve As Object
          Dim PointsObject As Variant
          Dim LocStart0 As Object
          Dim LocStart1 As Object
          Dim boolstatus As Boolean
          ' Select curve 0
          Set Curve = vSegs(0).GetCurve()
          PointsObject = Curve.Evaluate(0)
          Set LocStart0 = swDoc.CreatePoint2(PointsObject(0), PointsObject(1), PointsObject(2))
          boolstatus = swModel.Extension.SelectByID2("", "SKETCHSEGMENT", PointsObject(0), PointsObject(1), PointsObject(2), False, 1, Nothing, 1)
          ' Select curve 1
          Set Curve = vSegs(1).GetCurve()
          Set LocStart1 = swDoc.CreatePoint2(PointsObject(0), PointsObject(1), PointsObject(2))
          boolstatus = swModel.Extension.SelectByID2("", "SKETCHSEGMENT", PointsObject(0), PointsObject(1), PointsObject(2), True, 1, Nothing, 1)
          ' Create surface loft
          swModel.InsertLoftRefSurface2 False, True, False, 1, 0, 0
          ' variables for CreateLoftSurface
          Dim swModeler As IModeler
          Dim CurveArray(2) As Object
          Dim BBlendClosed As Boolean
          Dim BForceCubic As Boolean
          Dim GuideCrvArray As Object
          Dim StartMatchingType As Integer
          Dim EndMatchingType As Integer
          Dim NormalAtStartSection As Object
          Dim NormalAtEndSection As Object
          Dim StartMatchingFaceList As Object
          Dim EndMatchingFaceList As Object
          Dim DegeneratedStart As Boolean
          Dim DegeneratedEnd As Boolean
          Dim StartPointOfStartSection As Object
          Dim StartPointOfEndSection As Object
          Dim SectionIndexStart As Integer
          Dim SectionIndexEnd As Integer
          Dim GuideIndexStart As Integer
          Dim GuideIndexEnd As Integer
          Dim LoftSurface As Object
          Set CurveArray(0) = vSegs(0)    ' Sets first curve
          Set CurveArray(1) = vSegs(1)    ' Sets second curve
          BBlendClosed = False            ' False for non-closed
          BForceCubic = False             ' False for not forcing cubic surface
          Set GuideCrvArray = Nothing     ' Don't have a guide curve
          StartMatchingType = 0           ' Match none
          EndMatchingType = 0             ' Match none
          Set NormalAtStartSection = Nothing  ' Not used
          Set NormalAtEndSection = Nothing    ' Not used
          Set StartMatchingFaceList = Nothing ' Not used
          Set EndMatchingFaceList = Nothing   ' Not used
          DegeneratedStart = False            ' Not used
          DegeneratedEnd = False              ' Not used
          Set StartPointOfStartSection = LocStart0    'Start point of curve 0
          Set StartPointOfEndSection = LocStart1      'Start point of curve 1
          SectionIndexStart = 0
          SectionIndexEnd = 1
          GuideIndexStart = -1
          GuideIndexEnd = -1
          ' Create the surface loft
          Set swModeler = swApp.GetModeler
          Set LoftSurface = swModeler.CreateLoftSurface(CurveArray, BBlendClosed, BForceCubic, GuideCrvArray, StartMatchingType, EndMatchingType, NormalAtStartSection, NormalAtEndSection, StartMatchingFaceList, EndMatchingFaceList, DegeneratedStart, DegeneratedEnd, StartPointOfStartSection, StartPointOfEndSection, SectionIndexStart, SectionIndexEnd, GuideIndexStart, GuideIndexEnd)
