I am relatively new to SW and am trying to form a solid out of the 6 surfaces I created. However the try to form solid check box is grayed out and I am not sure why. Can someone help me with a workaround to get a solid from the surfaces or let me know as to possible reasons the box is grayed out?
Thanks in advance
N
When you start the loft and select the sketches, drag the green connector dots to the same side on both sketches. Then right click anywhere and click "show all connectors" and position the light blue dots so that the lines joining the two sketches don't cross.
